e36 air flow meter
    e36 air flow meter
    Message originally posted by: jeremy mccammon
    anybody any pictures or ideas for mounting the afm on an e36 2.5 build?
  • pnutter21
    • 54
    Re: e36 air flow meter
    Jeremy,
    have you looked at the pictues posted in the post listed called AFM (Air Flow Meter)?
    cheers
    Peter
      Thanks peter, have seen those pics, neat job. However on the e36 engine the inlet manifold and throttle housing come much closer to side panel such that the standard 90 degree hose does not fit.Ihave tried aluminium hose ducting and modified its shape ,but does not look great!cheers.
      • teazle
        • 52
        Hi Jeremey
        A pic of my m50 in a cabrio is under "BMW power" in Sportster messages if that helps.I had to cut 3.5 " out of the inlet manifold to get it all inside panel, worked well.Cheers C
          THanks Chris, that is one I hadnt thought of.Did u use the marlin radiator?Do u have pictures of the cooling hoses and plumbing? cheers jeremy
            Message originally posted by: Chris C
            Hope the chat helped, maybe see you at Brands Hatch
            aii the best Chris
