Getting FMB weighed
  • djj_engineer
    • 405
    Getting FMB weighed
    I took FMB to the local weigh-bridge.
    It was 460kg for the front and 520kg for the rear. 980kg total
    However it has got about 8 gallon of fuel so the empty total will be different.
    I fact thinking about it the more fuel in the tail the lighter the front is and the heavier the rear.
    I need to get the wheelbase of the car as well as the distance from the centre-line of the fuel tank to work out the approximate values.
  • Harry
    • Dec 2012
    • 239
    Re: Getting FMB weighed
    Good afternoon,
    Is FMB a roadster ? as I believe they weigh about 750 KG with the Marina / MGB engine etc fitted, I might get mine weighed once I've finished, I like to keep the car as light as possible, but I think I've added about 50 lbs by using the MGB gearbox.
    • lizbillings
      • 828
      FMB is a Cabrio V8.
      • Harry
        • Dec 2012
        • 239
        Hi Liz, well that's that cleared up then, I do like the V8s !
