Rear Light Wiring
  • dave_clutterbuck
    • Jun 2012
    • 260
    Rear Light Wiring
    All being well at the weekend I will make progress in finishing my car fit hood, boot lid, boot flooring and rear lights then off for MOT.
    I have lost my jottings for wiring rear lights tail, brake and indicators.
    I can do it with multi meter tester but if anyone knows where the black, brown, green and red wires go please let me know.
    Dave
    Re: Rear Light Wiring
    Hi Dave
    The following colours are for the ' Premier' wiring loom
    N/S tail light Slate/red
    O/S tail light Slate /black
    N/S indicator Black/White
    O/S indicator Black/Green
    Brake light Black/Red
    Rear Fog Slate/yellow
    Reverse light Black/Purple
    Fuel Pump Black/Yellow
    Fuel Gauge Blue/Black
    Hope we'll see you again at Sheldon soon.
    Regards Alan
    • dave_clutterbuck
      • Jun 2012
      • 260
      Thanks Alan
      I must have the 'budget' wiring version.
      I have different colours to the rear lights, although I have now traced them back to the joins to the colours you say above.
      I am hoping that I will wire the lights up and they will all work first time.
      Sheldon looks possible August / September where has the year gone.
      Dave
      • dave_clutterbuck
        • Jun 2012
        • 260
        All back together everything seems to be working as it should, a drive round the block to check all is OK then off for MOT.
        Had a bit of trouble with stale petrol put 2 gallons in it started OK then gradually spluttered to a halt and would not restart.
        Syphoned stale petrol then put fresh petrol and it fired into life after a few minutes of turning over.
        I now have 30ltrs of stale petrol, I am wondering wether to risk putting a gallon in every time I fill up.
        Dave
          go for it, or use it in the mower!
          • djj_engineer
            • 405
            I use it on my Fergy Tractor 4.6:1 compression and it burns anything that you can set fire too!!!!
            Derek
