New owner
  • twissy
    • Jul 2014
    • 27
    New owner
    Hi Guys. I've been on the lookout for a kit car for a couple of months now and saw an ad on Gumtree for the one in the pics. At a grand it seemed too good an opportunity to miss, so I bought it unseen and had it delivered by shiply.
    As expected it wasn't as good looking as the pics, but not too bad. I'm hoping someone on here will know something about the car as there is a sticker on it showing Marlin club member 2008 (I have now joined also). The logbook says it has a 1360cc engine.....is this possible on an A series? The side pipe is very loud, and it runs as if it has an uprated cam. It has been sat a couple of years so it probably needs a bit of a tune up.
    I foolishly booked an MOT for Friday afternoon, but at least I can find out what needs doing. I spent this evening sorting all the lights as only one headlight, indicator and tail light was working! Tomorrow evening is set aside for a new horn and steering rack gaiter.
    If I do get the car on the road I hope to see some of you at Donnington!
    John
    Re: New owner
    Welcome to Marlin ownership. 1360 cc is possible but more likely 1340 which is 60 thou oversize. Standard bore size for 1275 is I think 70.6mm so using 73mm pistons gives 1340. Anything over that requires offset boring the block as the walls between no 2 and 3 cylinders is on the limit and a change to the piston stroke to up the cc. I believe it's possible to achieve close to 1500 but that requires a lot of work and deep pockets. Twin cam is another possibility using if my memory is correct a BMW K1 motorbike cylinder head.
    Hope to see you at Donington
    Where are you based?
    Regards Alan
      Re: New owner
      13/60 is a possible Triumph Herald engine although the exhaust would be on the right. what's the engine number any chance of a picture of the engine bay.
      • twissy
        • Jul 2014
        • 27
        Re: New owner
        Regards Alan
        Thanks for the info Alan. I knew there was a max for an A series 1275 and thought it was around 1340, and as you say anything more would require "stroking".
        I'm in Nottinghamshire, 5 minutes from J27 of the M1.
        Cheers Ben. Definitely not a Triumph. I'll try to get a pic or two of the engine bay this evening. The small list I had to get it ready for Friday's MOT has increased three fold!
          Re: New owner
          PM sent.
          definitely a Marina Based roadster.
            Re: New owner
            That is a nice Marlin, damn shame I missed it as was local to me and am looking to swap out of the Vitesse 6 into a Marlin. Although my preference is a later Triumph 6 cylinder based hybrid (marina back en) car with doors and in a 'traditional' colour like green.
