Took Millie to the Dump
    I finally took Millie to the dump, oops I mean Civic Amenity Site, to get her weighed. She weighs 1120 Kg with me inside and the trunk on the back. Rear 680Kg Front 440Kg. I guess that the weighbridge rounds to the nearest 10Kg. A roughly 60%/40% Rear/Front distribution. Some web sites declare this to be ideal for a rear wheel drive car. If only I drove her hard!
  • lizbillings
    • 828
    Re: Took Millie to the Dump
    That seems a lot. Had you got a full tank too? regards Liz
      Hi Paul
      I loved your article in Pitstop - the dry comment:
      ".........here are the 10 main problems I had changing to Zetec"
      - really made me chuckle!
      I'm sure it was worth it......?
      Your title was misleading though - A Brazilian? - for an engine change?
      - I thought it was going to be down to the way you had trimmed it!!!!!!
      Ref weight, my Cabrio with the steel blocked BMW straight 6 weighed in at 960kg on the DVLA's weighbridge, including a full tank, but without spare wheel and hood/frame - they then add a nominal 70kg for a driver and declare the cars weight at 1,030kg (with me in it more like 1050kg!). So even adding 20kg for spare and hood it only gets to 1,070kg.
      - Paul's trunk, and or engine, must be heavy?!
