Lifting vehicles
    Lifting vehicles
    As I find I am falling to bits and suffer from a few problems with my back I was thinking about maybe making a ramp to lift the little marlin a bit higher off the ground. I have looked at all sorts of devices but wondered what other members use? Im thinking that something like the MR1 http://www.carlift-ramp-mr1.com/ sort of thing but engineered a bit better so it doesnt bend inthe middle might do the trick. thoughts?
    Re: Lifting vehicles
    There was a ramp, with a jack to lift it to the horizontal in a old Pitstop.
    Can you find it?
      Yes, that was the one that I made up. Still use it and as my drive is a 1:7 slope can run the car on to it without having to raise the end and work under it with plenty of room.
      Must have been back in 2007, 2008 when I did the mag. article.
      • Jonathanjeades
        • 225
        This is what I'm using, makes life a lot easier.....
        Available on eBay, around £1000-1200, fully hydraulic and 'mobile' all be it very heavy but it can be moved.
          Finally tracked it down to http://www.marlinownersclub.com/foru...5&d=1320759262
            Thanks for tracking that down. I have reproduced the article below. Love that scissor lift...wonder if 'er indoors would mind? hmmm.
            • RobA
              • 94
              HI Cameron,
              I made my own lift a few years ago, which I consider to be safer than the one above, as the base of the red type jack pivots on a pin (it was originally designed for uneven ground) but I found on a slight slope it made the ramp unstable when lifted. I used two agricultural trailer jacks instead.
              Anyone is welcome to come and see my lift if they are considering this type of system.
              Rob
                • 930
                Hi Rob,
                Can you post some photos of the lift?
                • RobA
                  • 94
                  Will try and sort some photos out over the next couple of days.
                  Rob
                  • RobA
                    • 94
                    Here is a picture of one of the agricultural trailer jacks I used instead.
                    Rob
                      See the broom has broken down again Rob!
