Tried the Sprite rad in the Roadster nose cone, placed on the chassis, this morning and engine side cowls fouled the rack so tin snips required to trim them down. Then the mounting flanges needed 1" cutting off the bottom edge to lower the top so it'll clear the bonnet.
End result is an alternative to the Viva item that has a better filler position and blanking plug that can be used for electric fan switch (I'm going to try and use the mechanical fan though) -
