Wipers
  • Mickaleen
    • Feb 2013
    • 55
    Wipers
    Hi,
    Is there an alternative wiper spindle sealing system to the Marlin( rubber grommets ) that I could use as a replacement please.
    Kind regards
    Mike.
  • CompoSimmonite
    • Jun 2013
    • 318
    Re: Wipers
    Mate had a leak from the wiper spindle seal on a nearly new Renault Espace. Renault wanted to sell him a complete wiper assembly as seal not available as a separate part. In the end he found a valve stem seal from his spares box fitted perfectly so I wonder if the same would work on your car.
    • Mickaleen
      • Feb 2013
      • 55
      Re: Wipers
      Hi,
      Thank you CompoSimmonite for your suggestion, will give this go.
      Kind regards
      Mike.
        Re: Wipers
        Maplin do a box of small assorted diam 'o' rings maybe one of them would also work?
        • Mickaleen
          • Feb 2013
          • 55
          Re: Wipers
          Hi tony,
          Thank you for;---
          Kind regards
          Mike.
