Soda Blasting
    Soda Blasting
    I thought it would be nice to get my rocker cover on the Marina Roadster back to metal so I can give it a proper respray, and whilst I was at it, maybe the carbs could do with a tickle to bring them up. Soda blasting seemed to be the answer. I looked up prices of starter kits and found Eastwood in the USA did a kit with everything in it for $40. So I found the same kit in the UK - sold by Frost - and it's £66. $40 is about £25 so what's the other £41 for? Postage?
    A £25 kit is fine but at £66 I'm going to make my own!
    Take care of small metal stripping jobs with a siphon blaster attachment that doesn't require a full machine. These spot blaster kits connect to your shop air compressor or pressure washer for instant paint removal capability.
  • CompoSimmonite
    • Jun 2013
    • 318
    Re: Soda Blasting
    Mate put his motorbike carbs in a cheap unltrasonic cleaner from Lidl and they came up great. I'd buy one myself if I couldn't borrow his whenever I need
    Paul H
    • djj_engineer
      • 405
      Re: Soda Blasting
      I have a grit blasting cabinet if you want to come up and use it. It will easily take a rocker box
        Re: Soda Blasting
        Cheers Derek I might take you up on that
        • rooha
          • Feb 2014
          • 122
          Re: Soda Blasting
          you could always redneck it.........
          • mark westbrookwhite
            • 146
            Re: Soda Blasting
            Please excuse my ignorance I have never heard of soda blasting!!! I assume it is gentler than bead or silicon blasting. and I also assume I can use my sand blasting gun.
            Mark.
