Not far off now.
  • Harry
    • Dec 2012
    • 239
    Not far off now.
    Evening everyone, I must say, I'm months behind with this car job, I thought I'd have it on the road 2 month ago, but with one thing and another eh ? anyhow I'm almost there, carpets in, fitted the trim etc to the transmission tunnel, seats cleaned up and fitted along with the belts, I was going to replace them but apart from being a bit out of date, there's very little wrong with them. I'm just fitting a new fuse box ( There were two Continental type boxes fitted) The wiring is all over the place but seems ok, I've removed 25% of it as it was redundant and I'm sure there's more that need not be there ? I've got to swap the speedo from the Marina version to the MGB version, it would be easier if there was a conversion fitting to go on the end of the cable. I might fit a reversing light as there was none fitted to this car. One day I will remove the Dashboard as it looks a tad odd and in need of a good sorting out, I hate the ignition key being behind the steering wheel, lol.
