Hope you can help? Need to know what gear oil to put into the above box! Would any modern alternative do? Sugestions please. Graham
Gear Oil (Morris Marina)
Tags: None
Re: Gear Oil (Morris Marina)
I would have thought EP90 or if you can't get that then EP80 which is what I have recently used on my Triumph O/D box (complete drain & refill).
Thanks for your help Neil. Just need to find out to find some now. Graham
I obtained my EP80 from my local motor factor, he hadn't got any 90 which the book recommended. As long as you use Gear Oil which is designed for Extreme Pressure (hence the name EP) you should be ok.
