I've bought her a Christmas present!!
  • nigel
    • 35
    I've always had the impression that the cooling capacity of my cooling system is a bit marginal. It's never let me down but I haven't been out in any ambient temperatures above the mid 20s C. But at a sustained 70mph at those sort of temperatures there is a noticeable increase in the coolant temp to just short of 100 degrees C.
    I had this rad custom made by Radtec, based on an Escort MK1/2 rad. (blatantly copied from Ian Morris but with different pipework)
    New Rad 2 by MarlinBuild, on Flickr
    It has a 42mm core thickness, a 30% increase on the current one. It also allows me to use the full 41mm bore of the original cooling system pipework instead of the 35mm I was restricted to. I've had a 1/8 NPT boss put in the top tank for the coolant temp sender and a M22 boss in the bottom for a fan switch. I'll probably go for something like an 88 / 78 degree switch on the basis that there's likely to be a 10 degree(ish) temperature gradient from top to bottom of the rad so the fan will kick in at a coolant temp of about 98 degrees. I'm running my cooling system at 1.3 bar with a 30% antifreeze mix so I'm guessing that the boiling point of the coolant is around 110/115 degrees so the 88 degree switch should give me adequate margin.
    There's probably a lot of guess work there but I can always change the switch if it proves to be necessary!!
    So I've got a little project for after Christmas and I will feel a lot more comfortable if I take the car to warmer climates in the summer....................
    And Happy Christmas to the Sportrster.
  • keith_h
    • 549
    Re: I've bought her a Christmas present!!
    If it doesn't already have one I would have a drain tap fitted, especially if you are going to be experimenting ?!
      • 930
      What motor are you cooling with this setup?
      • nigel
        • 35
        Keith, I figured that the temperature switch would act as a crude drain point for the rad.
        I'm running the BMW M50 2.5L straight six. This radiator has the same core thickness and an almost identical frontal area as the rad fitted to the donor vehicle that the engine came from. And the bonnet has a lot more vents to reduce the amount of hot air trapped around the engine!!
        So I think it should provide all the cooling I need....................
        Time will tell!!
