These are the articles up to Issue 181 Apr/May 2014 - and where to find them in Pitstop.
Hope it helps
Rgds DC
Berlinetta Pitstop Articles – to 181 Apr/May 2014
Berlinetta General
A BREATH OF FRESH AIR Steve Aucock Aug 89
BERLINETTA Steve Aucock Feb 90
BERLINETTA TIPS Phil Steele Jun 90
BERLINETTA OOMPH! Don Collins Apr 92
MY CAR WILL NOT START David Kindred Dec 91
BERLINETTA TOPICS Len Ball Aug 92
BERLINETTA TIPS David Hobbs Jun 92
BERLINETTA MODS A D JOHNSON Aug 93
MORE BERLINETTA MODS! Colin Reeve Aug 93
TECH TIPS from Phil Robertson, Berlinetta Tech. Adviser Mar 88
MODIFICATIONS Len Ball Apr & Jun 89
DEVELOPED THOUGHTS ON THE BERLINETTA Phil Roberts Dec 89
Berlinetta - Seeking Advice Owen Hawkes Feb/Mar 01
Reply from Paul French to Owen Hawkes Jun/Jul 01
Tips cribbed from Wessex KCC Newsletter Apr/May 01
Repair/Restoration Tony Johnson Jun/Jul 03
Transforming a Berlinetta to LHD James Dresch JunJul 10
Body Mods, Water Ingress, & Painting
DOOR HINGES Jim Davis Sep 87
RAIN CHANNELS Peter Hare Aug 91
TROUBLE WITH BERLINETTA DOORS John G Wilson Oct 95
BERLINETTA WINDOW CHANNELS (AGAIN) Mark Roberts Feb 96
Berlinetta Technical Points Apr 96
Berlinetta Wings Tony Johnson Oct/Nov 01
Water Ingress David Ison Feb/Mar 03
Re : Water Ingress Alan Hogg Aug/Sep 03
Roll bar for Marlin Berlinetta James Dresch FebMar 10 Berlinetta Pedal Box Seals Jeremy Carrington Apr/May 2011
Wind Deflector Bob Cawte
Brakes, Clutch & Hydraulics
(FORD) FRONT BRAKES Chris Wild Dec 91
PEDAL BOX HAZARD (1) Mike Middleton Apr 93
PEDAL BOX HAZARD (2) Tom Jones Dec 92
“SPRINGY“ HANDBRAKE Mike Middleton Dec 92
BERLINETTA PEDALS Chris Wild Apr 94
BERLINETTA Handbrake Garry Christmas Oct/Nov 00
Bleeding Brakes John Hammond Oct/Nov 01
Electrical, Instruments and Interior
BUILDING YOURSELF A “LIGHTS LEFT ON” WARNING DEVICE K L Martin Jan 89
BAD STARTING/BALLAST RESISTOR Don Collins Apr 92
SIDE REPEATER INDICATOR LAMPS Barry Greenhalgh Sep 88
Berlinetta - Tonneau Cover, Rear Seat Belts Paul Snook Aug/Sep 00
…………………..Response from Phil Hide Oct/Nov 00
BERLINETTA Tonneau and rear seat belts Phil Robertson Dec 00/Jan 01
Wiring Diagram for a Ford 2.0 DOHC Ian Hickson Jun/Jul 02
Pinto Engine Management System Wiring Theo Thomas Oct/Nov 02
Electronic Ignition System Stephen Middleton Aug/Sep 03
Lamps and Clamps Keith Howell AprMay 08
Nice dash for not a lot of dosh 1 Donnie MacDonald Dec08 Jan 09
Nice dash for not a lot of dosh 2 Donnie MacDonald FebMar 09
Nice dash for not a lot of dosh 3 Donnie MacDonald AprMay 09
Fitting an Electronic Speedo Nick Teasdeall Jun/Jul 2012
Drawing Instrument Dials on Your PC Keith Howell Oct/Nov 2012
LED Lighting Dave Kitson Jun/Jul 2013
Megajolt Fitment David Siddall Dec/Jan 2012
Engines
BERLINETTA ENGINE CHANGE Phil Robertson Nov 88
Berlinetta – new engine Mark Roberts Jun/Jul 01
High torque cam for Pinto ? Tony Johnson Oct/Nov 02
…………………..…..Rely from John Hammond Dec 02/Jan 03
Express Engine Transplant Terry Reed Dec/Jan 2011
Hot Rod Berlinetta Roger Johnson Apr/May 2011
Exhausts
Exhaust System Walter Styles Apr 90
EXHAUSTING BERLINETTAS Dave Ruslin Aug 89
EXHAUST SYSTEMS Brian Gadd Feb 93
BERLINETTA Exhaust Garry Christmas Oct/Nov 00
Heating, Overheating & Cooling
How cool are you? Peter Crowther Dec 09 Jan 10
Heaters - Comment from John Hammond OctNov 07
AntiFreeze in 2010 Part 1 Derek J Harris Dec/Jan 2011
AntiFreeze in 2010 Part 2 Derek J Harris Feb/Mar 2011
Hoods & Hardtops
BERLINETTA HOOD CATCHES Dave Hunt Dec 93
BERLINETTA HOOD IDEAS Alan Darbyshire Oct/Nov 98
Berli Hood Fastening Roger Johnson Apr/May 02
Hood to Cant Rail Fastenings Phil Robertson Jun/Jul 02
HOOD CANT RAIL WATERPROOFING Aug 89
Petrol Tanks, Carbs, Fuel
BERLINETTA FUEL GUAGE CHRIS WILD Dec 93
Cheap ‘n’ cheerful manual choke conversion Donald Macdonald Oct/Nov 06
Petrol Tank Straps JunJul 09
Rear Axle, Diff, Gearbox & Overdrive
FITTING A SIERRA 5-SPEED BOX Brian Gadd Feb 93
Rear Axle Bushes Ray Drinkwater Mar 87
A few thoughts on Berlinetta axle ratios Phil Robertson Jun 95
Berlinetta gear box Mark Barnes Jun/Jul 01
Berlinetta Propshaft Problems? Mark Roberts Jun/Jul 02
Seats
BERLINETTA SEATS Malcolm Calder Apr/May 99
Berli Question - Seats Roger Johnson Apr/May 02
………..Reply from From Peter Cork Jun/Jul 02
Springs, Steering & Suspension
SPRINGTIME Don Collins Apr 92
SPRINGS AINT WOT THEY USED TO BE Dave Rusling Oct 92
STIFF STEERING Dave Rusling Oct 92
SPRINGTIME Geoff Beech Feb 92
THE REAR SUSPENSION Brian Gadd Feb 93
THOUGHTS ON BERLINETTA SUSPENSION SETTINGS Don Smith Apr 94
BERLINETTA SUSPENSION...THOUGHTS THAT 'SPRING' TO MIND Bob Copping Jun 94
BERLINETTA (CORTINA 4 FRONT SUSPENSION) STEERING RATTLES David Hobbs Jun 94
BERLINETTA SUSPENSION Mar 95
BERLINETTA STEERING VIBRATION - - - An Answer ? Tony Johnson Jun/Jul 98
“THE CLONK” Alan Darbyshire Oct/Nov 98
BERLINETTA - “THE CLONK” Dave Hunt Dec 98/Jan 99
Berlinetta Front Suspension Trevor Benjamin Dec 98/Jan 99
Berlinetta Comments from Phil Robertson Feb/Mar 99
More on “The Clonk” Feb/Mar 99
“LE CLONK” ! Malcolm Calder Apr/May 99
TROUBLE WITH YOUR SUSPENDERS Andy Stephenson Jun/Jul 99
Banging rear ends on Berlinettas John Hammond Jun/Jul 99
Berlinetta Suspension & Steering Tony Johnson Jun/Jul 99
Berlinetta V8 build - Part 2 - ‘Teething Problems’ Paul French Jun/Jul 00
Springs, rearward-moved engines & how to make things more comfortable John Hammond Apr/May 01
Berlinetta Springs Tony Johnson Jun/Jul 01
Springs and Things John Hammond Aug/Sep 01
Berlinetta Springs Tony Johnson Oct/Nov 01
For Tony Johnson, ref Springs John Hammond Dec 01/Jan 02
From Tony Johnson Jun/Jul 03
Coil Over Shocks Berlinetta Martin Rodgers Oct/Nov 02
A Longer Steering Column Paul Condliffe Apr/May 03
Best Set up for Rear Springs Berlinetta Martin Rodgers Oct/Nov 02
Wheels & Tyres
TYRES Ron Jamieson Dec 91
“WOBBLY WHEELS” (Comment on previous article) Steve Aucock Apr 90
Berlinetta Tyres Tony Johnson Oct/Nov 01
Tyre Sections, Tyres and Rim Sections John Hammond Dec 01/Jan 02
From Tony Johnson Feb/Mar02
Wheel & Tyre Sizes “Biro” Feb/Mar02
Wheels Tyres etc Peter Daveny Apr/May 02
Alloy Wheel Cleaner Biro Apr/May 04
Workshop Tips etc
SAFETY TIP (2) Mike Bagnall Feb 93
Bowden Cables Peter Morris Oct/Nov 06
Solderless Nipples without playing with fire! David Prowse Dec 06/Jan 07
Car Ramp Hugh Cumming OctNov 07
Berlinetta Builds & Rebuilds
BERLINETTA BUILD Trevor Benjamin Aug 92
BERLINETTA BUILD UP Phil Robertson Nov 86 & Jan 87
Five Wheels on my Wagon Mark Roberts Oct 93
BERLINETTA 1661 PART ONE J G Wilson Nov 94
HAVE YOU GOT A RECEIPT FOR THOSE WHEELS? (Abridged) Jon Orme Dec 95
BERLINETTA MODS Steve Large Jun 96
Response from Bob Copping Jun 96
BERLINETTA V8 BUILD - Q813 DPG (Abridged) Paul French Feb 97
BERLINETTA MODS Tony Johnson Jun/Jul 98
Dane's Moll Dane Crosby Dec 03/Jan 04
Moll Part 1 –where the Berli story really starts Dane Crosby AugSep 07
Moll’s Saga (No 2 of hundreds) Dane Crosby Dec08 Jan 09
Moll’s Saga (The last part? I doubt it!) Dane Crosby FebMar 09
My Berlinetta History 1986 – 2007 Jeremy Carrington OctNov 07
A Marlin Story begins…….. Michael Davidson Dec09 Jan 10
A Marlin story continues…….. Michael Davidson AprMay 10
The Life and Times of a Marlin Owner 1 Dave Hunt FebMar 10
The Life and Times of a Marlin Owner 2 Dave Hunt AprMay 10
The Life and Times of a Marlin Owner 3 Dave Hunt AugSep 10
Life & Times of a Marlin Owner 4 Dave Hunt Dec/Jan 2014
Berli Build UK & Australia 1989-2014 M Brooks/ J McLaughlin Feb/Mar 2014
Berli Respray and Refit Gary Woolridge Dec/Jan 2014
Hope it helps
Rgds DC
Berlinetta General
Engines
Exhausts
Hoods & Hardtops
Seats
Wheels & Tyres
Workshop Tips etc
Peter.
