Fitting a removeable steering wheel
  • keith_h
    • 549
    My YKC Roadster is based on Sierra GLS running gear and as I find agility is inversely proportional to age I though I would treat myself to a woodrim/leather removable steering wheel in the hope that it would make life a little easier getting in and out. I used the column from the GLS exactly as is and have all the multifunction switching on the column as is. Can anyone recommend a supplier. Is there a system that would allow me to keep the centre horn button and if so, how does it work? (sliprings?)
    • 929
    Re: Fitting a removeable steering wheel
    I would be careful. I can't remember where I saw it, but there has been at least one incident where the steering wheel has come off in the drivers hands totalling the car. The first thing I would check is that the mechanism for locking the wheel to the column is well engineered and is unlikely to be released by accident. I'd also post a question on the Southern Kit Car forum as I'm pretty sure that was where I came across it.
    • scott h
      • Mar 2013
      • 670
      Removable steering wheels are common in motorsport. It is usually a two part kit. A male part is welded to the column and a female boss, which includes the latch, bolts to the wheel. Just google quick release steering wheel. Not sure about the horn though, apart from a wire that you would have to connect each time.
      • keith_h
        • 549
        Thanks for that Andy - I guess a compromise is to simply settle for a smaller diameter wheel (I'm using the Sierra wheel at the moment) but I am guessing that will make parking and tight maneuvering so much more difficult
          How about a D shaped wheel with the flat at the bottom? Good compromise.
            • 929
            I have a small diameter wheel and it's just as light as the Focus with power steering, but then I'm still using the original 185 profile tyres!
              • 929
              http://www.ebay.co.uk/itm/like/32160...f14=108&ff19=0
              That looks like a nice wheel
                which sierra wheel Keith? There are some which are a bit smaller - like off the cossies? (three spoke)
                  • 1226
                  Hi Keith, With the Sierra steering column you would still be using an adaptor with the two contact horn rings. So you would have a centre of steering wheel push horn. I have one fitted to one of my cars. Take a look at the release mechanisim and make your own mind up. I have no problem or doubts about using removable steering wheels. The bolts are high tensile and the length of projection/location is approx 18mm and tapered to boot.
                    登录 Facebook,与好友、家人和认识的人分享和建立联系。
                      • 1226
                      perhaps not located properly, been used on the track since the year blog. Who knows.
                        • 929
                        You might find this informative
                          • 929
                          And this was the crash!
                            Keith
                            Another option to consider would be to add an electric power steering unit to the Sierra column to allow you to use a smaller diameter wheel.
                            It has been done in a Cabrio - don't know if you have the space in a Roadster?
                            I have a Sierra column and Corsa electric motor you could come and have an experiment with when you are over this way if you would like?
                            Lee Hunter developed the idea for his Cabrio, and helped a couple of other members to convert their Sierra columns too, so it is not a daunting job.
                            • keith_h
                              • 549
                              Hi Cameron, it is a 15" dia. 3 spoke (see photo). Are you saying that I might be able to get a straight swap from a Sierra Cosworth that will fit?
