Hi from Norfolk
  • Norfolk V8
    • Mar 2015
    • 3
    Hi from Norfolk
    I don't have a Marlin yet , but do know from a friend of a friend, of a roadster that has not been advertised yet, as this is quite a way to travel , I'm trying to find out if we would actually fit in it ,previously we have had a Ford based Spartan & although I like the look of the Marlin Roadster just wondering if it could be too narrow inside for us, as think they are narrower than Ford Spartans, does anyone have any measurements ,width across between inside of the doors would be useful
    Re: Hi from Norfolk
    Seat width is around 15"
    more info
    here or there and here or there
    • Norfolk V8
      • Mar 2015
      • 3
      Re: Hi from Norfolk
      Thanks for the reply & great info ,but would still like to know the inside width between the doors
        Re: Hi from Norfolk
        2x15" plus 5/6 inch transmission tunnel.
        • Norfolk V8
          • Mar 2015
          • 3
          Re: Hi from Norfolk
          thanks that helps a lot
            Re: Hi from Norfolk
            Just popped out to measure my car (a MK2), narrowest point, chassis close to the floor, is 92-93cm from side to side. There is a cm each side extra at hip height when seated. The Transmission tunnel at that point is 16cm.
            • JimboM
              • Aug 2012
              • 10
              Re: Hi from Norfolk
              Hi, I have a Marlin Hunter SWB and live just outside Norwich if you wanted to size it up. I will look for response and I you do want to see her will send a contact by email. [email protected]
