Has the log in memory function changes
    Last year I think I logged in using my pass word once (OK maybe a few times). Now with the same computor set up I seem to have to log in every time I open the site which is daily or several times a day (even if I tick the remeber me box). Anybody else having this issue or is it just me and my rig.
    Alan
    Re: Has the log in memory function changes
    Hi Alan, sorry you are having this problem. The "remember me" function hasn't changed so it is likely that something on your pc has. The most likely cause is that either you have set your browser to delete history and cookies on exit or you are not accepting cookies at all. You will need to clear the cookies for vbulletin then the next time you log in it should reset and end the problem.
    If you are using Chrome as your browser then type chrome://chrome/settings/cookies into the address bar, type vBulletin in the search box and it will allow you to delete vbulletin.com cookies. If you use a different browser let me know and I will tell you how to clear it.
    Hope this helps
    C
      Thanks for that - I will check
