Roadster rear suspension
    Message originally posted by: chris Reeson
    I am fed up with springs hitting the body on hard cornering and dampers that are supposed to work at about 45 degrees. Has anybody else fitted a panhard rod, anti-tramp bars and/or vertical dampers? Seems like I need some proper axle location - who has already been there and done that?
    Re: Roadster rear suspension
    I had a similar problem and discovered that the o/s lower seat-belt mounting bolt was fouling the spring under certain conditions. I removed the external load-spreading washer I'd added to the bolt and no more clonking. A panhard is definitely a good idea - Marinas were renowed for their pioneering use of rear-wheel steer.
    Check all the bushes and dampers - I have poly shackle-bushes which helped stiffen things up, and plan to add poly spring pads and poly spring-eye bushes too. I also plan to replace the rear Spax with Gaz units - I've been really impressed with the ones I fitted at the front, they seem much more positive than the original Spax.
    A logical extension is a full 5-link rear with turretted coilover units, which looks a feasible solution. I believe it's been done, but I can't remember the chaps name...
      I did this to a previous car, which was Triumph IRS based. It was massively better. I don't want to be quite as drastic with this car!
      • AndrewKB
        • 124
        See this earlier Forum message - http://www.marlinownersclub.com/forum.php?read=54&cat=0 - or just look for "Panhard rods" in the message list.
