Anyone need spares (name yer price - collection by buyer from Milton Keynes)- any of the following - will require reconditioning depending on you assessment of the parts, can post photos on request of relevant item. The entire engine ran fine before the car was 'disappeared' then recovered, but engine in pieces.... Will eventually take whatever is not collected over to a scrap metal yard at end of April 2015. So have the following;
1. Head with valves and springs all still in place, except for the engine bolts and bolts that hold down the rocker arm to the head
2. All push rods
3. Pistons/con rod/bearings
4. Crankshaft
5. Engine block - no sump or oil pump
6. Complete working 4 speed gearbox and gear lever, and mating plate
7. Twin stromberg carbs in a bucket, pulled to pieces
Regards,
avid - [email protected]
2. All push rods
4. Crankshaft
Regards,
