Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roadster.
    Re: Operation Blown Fuse Replacement: the total rebuild diary of a Marina based Roads
    I just ordered two from Earlpart.
    • old_n_notpastityet
      • Apr 2015
      • 197
      That Dashboard would look good in an Aeroplane Cockpit, plenty of Clocks your gonna have to get eh !..Looks very nice, mine is nice from a distance but mainly works and not too complicated ! will keep an eye peeled for the brake drums ime always surfing E-Bay.
      • DamnedFrog
        • Oct 2014
        • 66
        Hello
        I am actually a private pilot... hence the retro aero look of my dashboard
        Just wait for the riveted aluminium parts I'm designing for the cockpit layout... sunglasses would be mandatory
        Thanks for the sources for brake drums, I'll try there!
        Christophe.
        • DamnedFrog
          • Oct 2014
          • 66
          Hello all
          Finaly I managed to give some time to the Marlin!
          I dismantled the remaining components from the chassis that is now completely naked... except the windshield that is glued with silicon bond. I'm afraid to break it
          I sandblasted all the parts after a chemical attack of the paints and now repainting with two components epoxy would occur soon.
          I decided to change the dampers, even if they seem to be good and still full of oil, they're corroded and awfully painted, which I cannot stand
          The Morris Marina featured an original front damper system, which is replaced on Roadsters by regular tubular dampers.
          But which ones ?!? On mine, these parts come from a French car, since the word "HAUT ->" is engraved on the external tube to point at top end.
          Maybe Renault or Peugeot parts, but which one ?
          Does anyone knows what is the donnor for the front dampers of Roadsters ?
          Rear ones are still in stock anywhere, this is amazing for a 40 years old car
          Regards,
          Christophe.
            #20
            You require Triumph Herald REAR shocks to fit the front of a Marlin roadster. Available from Rimmer brothers
              #21
              Triumph Herald rear dampers were the factory recommendation for the front on Marina-based Roadsters, but any damper with an integral bumpstop & which has the same open/closed dimensions as the Triumph unit could be substituted.
              As regards the windscreen sealant - you can (in the UK at least) buy a dissolving agent for silicone sealer which may make things easier. I have used it & it was quite effective.
              • DamnedFrog
                • Oct 2014
                • 66
                #22
                Many thanks for dampers and solvent
                I'll order all ASAP.
                Christophe.
                  Silicon seal remover, regularly to be found in Lidl - at least here in 29, as above very effective!
