What is your prefered paint for chassis?
  • DamnedFrog
    • Oct 2014
    • 66
    Hello all
    I must now order high quality, anti-rust and impact resistant black paint for the skeletton of the Roadster.
    Is the "POR 15" product line as good as they claim? Has anyone some experience with it ?
    Regards,
    Christophe.
    • 929
    Re: What is your prefered paint for chassis?
    A number of the guys on the skcc forum swear by it. Personally I've always used dulux weather shield over a good red oxide primer.
    • rooha
      • Feb 2014
      • 122
      i've used Hammerite Underbody Seal which seems to be alright ...
      • gprentice
        • Dec 2014
        • 17
        Hi Christophe,
        I have used POR 15 paint and the tank sealer I found them both very good. The paint is not UV stable which is fine for underside but you need a coat of normal paint over the top if it is in the light. It cures more like an resin when exposed to air and is solid right through after a day.
        One word of warning don't get it one your skin, the only thing that takes it off is time. It is like getting super glue off.
        Graham
        • davidmartin720
          • 188
          The chassis on my Roadster used in all weather over the past 41/2 years of my ownership is good without hardly any rust. Talking to Ernie Warrender, he used to work for Marlin's in the 80's cutting out and shaping the aluminium bonnets, Ernie said Paul Moorhouse bought a job lot of grey micaceous paint from BT. [BT used this paint on the metal in their manholes.] The paint led me to think my chassis was galvanised, but Ernie's answer makes sense. Shortly after I received this information, there was a programme on TV about mining micaceous iron oxide. My chassis was also protected by Derek Giles using some paint he acquired from his work with the Gas Board, type of paint unknown. Several people have said Hammerite is too hard and chips easily, and the best paint is ordinary black gloss.David.
            I bet the trials or Land Rover communities would have sorted this one out
              • 1641
              I think they have. It's called mud! Available in a forest near you. Peter.
              • CompoSimmonite
                • Jun 2013
                • 318
                I use Wilkinsons satin black household paint on new Land Rover chassis.
                  I have used POR15 on motorbike frames - its brilliant and tough - much harder than hammerite. You can get grey undercoat and black top coat (you could just use just the top coat it is so tough). Its a pain to use once you open tin you have to use it all as the lid will only come off with a can opener (they sell it in very small tins as an option for that reason). You have to buy special thinners if you spray and clean gun throw brushes away. As earlier post said don't get on you its a week to wear off.
                  • CompoSimmonite
                    • Jun 2013
                    • 318
                    Rust Bullet is basically the same as POR15 - but cheaper
                    Explore Rust Bullet's premium rust inhibitors and concrete coatings-easy to apply, moisture-cured, & trusted by industries worldwide for lasting protection.
                    • leadfoot
                      • Apr 2016
                      • 115
                      I have used K-rust, followed by Zinc 182 then finished with Hammerite smooth on my chassis. I have to say that a friend of mine used POR15 on the wishbones of his Lamborghini Diablo kitcar and he applied it with a sponge. The result was beautiful and looked powder coated!
