Is wrapping the manifold a good way of reducing heat under the bonnet? What experiences have you had?
Exhaust Wrapping
Re: Exhaust Wrapping
It will reduce the heat under the bonnet a bit, especially beneficial if you have heat sensitive components or pipework that runs near the exhaust. The other benefit is that by keeping the exhaust gases hotter and therefore less dense they exit the system easier with a theoretical small increase in power. In practice I doubt you would notice any increase. A small risk when wrapping non-stainless pipework is that moisture can get trapped between the wrap material and the pipe causing corrosion which you won't be able to see. I sealed mine with several coats of silver heat resistant paint. Whether or not it worked I guess I won't know until the exhaust falls off!
Don't wrap cast iron manifolds. They will crack.Mk2 SWB Marina Roadster with a 1800 Fiat Twin Cam engine and 5 speed Abarth gearbox built in 1987
the heat has to go somewhere - wrapping moves it further along the system in theory
Ditto. Especially for Marina based cars. Not recommended by Peter Burgess the MGB guru.Originally posted by jon.cox View PostDon't wrap cast iron manifolds. They will crack.MOC member since 05/97
I agree with the "not wrapping cast Iron" here is the result if you do, you find out when the wrapping starts to weep soot
PS Rover V8
Hi . I reluctantly wrapped my stainless manifold (because I prefer the look of the naked pipes), not to reduce under bonnet temperature but to heat up the area around my o2 sensor. I have an air/fuel ratio meter that I can couple up to the signal wire from the o2 sensor and was puzzled why I did'nt get constant readings when the engine was warmed up. Eventually the penny dropped that because the o2 sensor on my system is a relatively long way from the cylinder head, the gases were not reaching the neccessary 500 degrees for the sensor to function properly. After lagging the pipework I'm getting much better readings which will allow me to fiddle around with ecu settings to optimise the air/fuel ratio. David
