steering column (ford sierra), improving fixing and support
  • Sportster-Green
    • Dec 2012
    • 141
    my sportster is equipped with a ford (sierra?) steering column.
    its fixed underneath the dash, similar the BMW donor, with some brackets towards the chassis.
    the bulkhead contains a rubber insert with a plastic bush.
    than it goes through the enginebay without any extra support until it merges the steering rack.
    this arrangement does not feel really stiff and well supported.
    has anybody made an improvement at the bulkhead-side, fitting a bearing, balljoint etc instead this rubber-supported bush?
    Re: steering column (ford sierra), improving fixing and support
    yup!
    See my Romero build diary
    [IMG]www.marlinownersclub.com/forum/attachment.php?attachmentid=3217&d=1365241633[/IMG]
    this was an idea I stole from the Robin Hood guys, its basically a bearing in a captive casing (from Bearing boys).
    • scott h
      • Mar 2013
      • 670
      I copied the same idea on my Berli. I went to a local bearing supplier and got a bearing to fit the plastic bush but here are some on Ebay http://stores.ebay.co.uk/Bolton-Bear...4.l1581&_pgn=2
      • Sportster-Green
        • Dec 2012
        • 141
        thanx for the reply guys...yeah thats the idea i also thought.....
        i´ve ordered now :
        from a local suplier...costs me 8,-euro inkl. shipping....i will retain the ford plastic bush with the triangular hole...this bush has an outer diameter of 25mm...so will be a tight fit inside the bearing...the bush will be hold by the scrub screws in the bearing...so should result in a precise guided column....hopefully...fingers crossed!!
        • Sportster-Green
          • Dec 2012
          • 141
          job done...but damn...its raining since yesterday afternoon...so no test drive possible.....
