Door hinge
  • StephenMF
    • May 2015
    • 5
    Door hinge
    The driver's side door hinge on my Roadster has fractured - see attached photo.
    Could anyone please advise how I can obtain a replacement?
    Thanks
    Re: Door hinge
    Bit late now but thats why there is a grease nipple on the top.Some one may have a spare so suggest you put a request on the wanted threads . If nothing turns up you could have a go at straightening it and rewelding. Or find a friendly engineering shop to knock up a replacement.
    The last seized one I saw snapped the pin off the chassis.
    • old_n_notpastityet
      • Apr 2015
      • 197
      Re: Door hinge
      First thing I would do is give it a good soaking with freeing oil and try to get that grease nipple out and put some freeing oil down there as well,and then leave it a while hopefully with patience tapping and twisting it a little at a time it will come free and come off the pin. Then get it welded or get some mild steel and make one, good luck with it
        Re: Door hinge
        Do you know which car the hinges came from? There are several companies that specialise in British sports car spares. Try Holden or Rimmer Bros.
          Re: Door hinge
          According to other posts in this forum they are Marlin's own design.
          I have seen similar but never the same.
          • CompoSimmonite
            • Jun 2013
            • 318
            Re: Door hinge
            If it's the same as fitted to my Roadster then you are welcome to one as I'm changing to suicide doors and A35 hinges (with Midget locks)
            • StephenMF
              • May 2015
              • 5
              Re: Door hinge
              Thanks for the tips Ben. At least I should be able to save the other door hinge!
              • StephenMF
                • May 2015
                • 5
                Re: Door hinge
                Thanks very much for the advice on freeing it up - I'll try it.
                • StephenMF
                  • May 2015
                  • 5
                  Re: Door hinge
                  That is a very kind offer. It might be worth a try if I can't find one locally (I live in Bucks). Does it appear to be be the same type as in the photo that I posted?
                    Re: Door hinge
                    they are simply a piece of steel with a bit of tube welded on the side. Should be easy to get a replacement made. In fact, looking at that one I bet that once it is off you could grind out the weld and remake it. I have a brand new one on my shelf if you need dimensions (but its not for sale!).
                      • Apr 2015
                      • 197
                      Re: Door hinge
                      Been surfin and found these http://www.albert-jagger.co.uk/products/hinges
                        Re: Door hinge
                        I stumbled across these Land Rover bonnet hinges whilst looking for same for my car, looks like they maybe useful for us for door hinges!
                        Aftermarket 4x4 Parts & Accessories Expedition & Overland Preparation Outdoor, Camping and Bushcraft Products
                          • Apr 2015
                          • 197
                          Re: Door hinge
                          good idea they sure could be usable from the look of em
                            Re: Door hinge
                            There is always the alternative, take the 'b****y doers off! Said in a poor Michael Michelwhite impression.
                              Re: Door hinge
                              ^ pub quiz knowledge showing then ; - ))))
