Need to change my speedo on my marina based roadster, any one any ideas on where i get one and isn't too expensive
Speedo
Tags: None
Re: Speedo
If it's anything like mine it's a pig to get out as it's part of a moulding with the rev counter and the car seems to have been built aroung the dash with no obviuous means of removal. In latest Pitstop mention is made of a stick-on electronic one - may be the simplest solution. If you're determined to change it, Marina OC should be able to help
Re: Speedo
Try Quiller triumph for ex spitfire etc smiths dials.
Re: Speedo
I swapped the Marina instruments for Dolomite (Smiths) ones from the scrapyard - when you could get them in scrapyards! Speedo seems to show about the right speed...
