Ceramic distributor cap socket (suppressor?)
  • keith_h
    • 549
    I have busted the middle ceramic socket that the coil HT lead plugs into on the distributor cap on my Ford 2.0 EFi DOHC type N9 engine. Am I correct in assuming it is a suppressor? Any ideas as to where I can get a replacement ?
    Re: Ceramic distributor cap socket (suppressor?)
    there are a couple of caps fitted to this engine but try here...
    • keith_h
      • 549
      My distributor cap is like this but each lead is conected via a ceramic cap and rubber cover and it is the ceramic connector that I have broken
      • keith_h
        • 549
        It has just occurred to me that they were installed to stop interference on old analog radio and tv transmission systems. Now that everything is pretty much digital are they necessary i.e. can I just leave them out?
          the part you need is
          Brand:BERU Part Number(s):0300413408 ProductName:Plug, distributor; Plug, coil
          which I think you can get from here
          http://www.carparts-worldwide.com/a/...er_ves_408.htm
