Bonnet piano hinge
    • 2447
    Bonnet piano hinge
    Hi all
    I am in the throws of fitting the bonnet on my roadster.
    I have the piano hinge supplied and when I offer it up with the two half's the hinge part appears to be to wide.
    It measures 9.5mm thick.
    Is this right, has anyone else fitted theirs and if so what is the thickness of their hinge?
    Did anyone buy a slimmer hinge etc.
    Re: Bonnet piano hinge
    Hi Adrian
    What sort of an edge do you have on the bonnet panels along the hinge?
    On my Cabrio it was just a straight cut edge: I had to trim mine to make the panels fit nicely.
    You have to be very brave, and remove less than you think is necessary and then repeat several times as you get closer and closer to a snug fit.
    Remember to allow for any rubber linings you intend to fit opn the copwl and bulk head, and make sure you set the gap you want between side panels and bonnet - using a hard spacer to hold this gap constant is useful.
    YIf you have a straigh edge you need to allow a 2mm gap between the edge and the hinge to avoid it fouling as you open the bonnet.
    If you have a folded edge along the edge of the bonnet, I have no idea how you are expected to make it fit!!!
    Hi all
      • 2447
      Maybe I need to look at someone else,s to get an idea.
      It's not folded so can be trimmed but I had some notion that, like the side panels, they were pre-fitted at the factory.
      Obviously you need to do the cut away for the windscreen wipers.
      Thanks for the info.
      • trevor_ford
        • 213
        Like Mike says, I seem to remember lots of trimming until it sat OK
          • 590
          Hi Adrian,
          As above. Lots of careful trimming.
          Full instructions to be found here in 3-13.pdf
          http://www.marlinownersclub.com/foru...3&d=1396553519
          http://www.marlinownersclub.com/foru...r-Build-Manual
          • keith_h
            • 549
            Hi Adrian,
            Lots of cold drinks and lots of measuring time available.
            Keith
              • 2447
              Ok so this is going to take some time, LOL.
              And theirs me thinking the wings were going to be the toughest.
              Wait till I get to them, again, LOL
              Many thanks for all the info, just one last question is the Piano hinge I have the correct one?
                • 2447
                Ok, Keith has just popped round and its exactly the same size.
                But now he has me thinking, do I go for a Stainless Steel one.
                More money, oh well.
