Bit of a mystery this one folks.
New carb fitted in June (new old stock) from the carb hospital chappie. Last one he had in the 1275 marina dept! Its a later HS4 but with the waxstat thingmy. Anyway, fitted and colourtuned and idle to midrange fairly spot on and flat out it picks up well and runs cleanly, but seems to run incredibly lean.
Midrange at about 50, but when putting power in, it is spluttering and misfiring like a bad one! If you ease off things smooth out again as things do if you turn the tap on fully. Today, in an effort to figure it all out, I opened (closed) the choke just when the misfire occurred and I was instantly rewarded with power and smooth running again. So probably a jet issue I think. Engine seems fairly standard with the exception of a 4 branch exhaust linking to a side exiting silencer.
May use the little programme that is available to aid SU jet selection, but any similar experiences out there guys?
Scotty
Scotty
