Back to a similar issue I had when I got the car, and after checking that I had a good spark and fuel was being pumped to the carbs I looked at the distributor again. The points gap has closed up so have reset and about to try again but while having a culpa thought I'd upload this video.
What do you guys think about the way the points arm doesn't align with the lobes on the disti shaft and the movement in the base plate, which obviously changes the points gap.
I was considering an exchange unit over the winter anyway as the black earth lead came off the base plate and has had to be soldered back on twice now.
David.
David.
