Fuel tank
  • beergutdave
    • 47
    Fuel tank
    Hi Has any one used the plastic type fuel tanks supplied by car builder solutions?
    What capacity tanks are you all using?
    I am looking at fitting one to a swb mk1 as my current tank's filler neck is level with top of the tank and im sure it will leak out if used like that.
    All info welcome.
    Thanks
    Re: Fuel tank
    My sons Mk1 uses a Reliant Robin tank that holds about 6gals the tank you have is probably a Hillman Imp tank.The main thing is to ensure the tank is installed firmly.As a gal of fuel weighs about 10lb.If you use a plastic tank dont forget to earth the sender unit and the filler neck.
      Re: Fuel tank
      Message originally posted by: Ben Mk 1 register keeper
      Oh Dave Do I know about your car? Can you Email me your Reg and if pos chassis number and any relevant details then I can update my records of Mk1 cars a pic would be nice.
      • paulhyder
        • 141
        Re: Fuel tank
        Yes Ben, i spoke to you in about 2002 or thereabouts and gave you some details, but unfortuntly extensions and house moves and sporting trials have got in the way.
        But am now back on track with the goal of using her to the Le Mans classic in july. Reg is LPU... not sure of the rest offhand. Regards Dave
          Re: Fuel tank
          Gotcha, thats the problem with this, now I know who you are Happy New Year Dave Thanks
          • FranklinLeicester
            • 380
            Re: Fuel tank
            The tank on my car has the low filler neck but I was given a bung to stop fuel spilling out. It consists of a wad of chamois leather shoved into a plastic bag. It is a tight fit so there must be a breather in the system. I t works fine with no spillage. Try this before going to a load of trouble.
            Franklin, Leicester
            • paulhyder
              • 141
              Re: Fuel tank
              NICE!
              • FranklinLeicester
                • 380
                Re: Fuel tank
                When I said I shove a bung in the filler neck, perhaps I should have made it clear that it fits in flush with the top of the filler tube so that you can pull on the plastic bag to withdraw it. The filler cap snaps down as normal.
                Franklin, Leicester
                • beergutdave
                  • 47
                  Re: Fuel tank
                  Well i decided to splash out and have a aluminuim tank made to suit. Thanks for the info.
