Re: Alfa 1750 running in HELP
is the ignition timing corect ??
what have you set the mixture screws too ?? remember they work opposite to 'normal' down draft carbs !! screw them full in and then 3/4 turn and leave..
Are the carbs balanced ??? you can get a proper tool for not a lot !!
and get the correct coil and fit the wires the correct way round !!
