My roadster marlin n series of 2456
  • jean
    • Oct 2015
    • 19
    Hello
    My roadster marlin n series of 2456m and it is on that basis
    Thank you
    Re: My roadster marlin n series of 2456
    Hello jean - another member from France!
    • jean
      • Oct 2015
      • 19
      yes southern France Avignon
        Chassis 2456 is likely to be an all Morris Marina donor car.
        It is impossible to tell exactly which Morris Marina the parts came from. Do you have any paperwork from the original builder.
        On your question regarding Brake Servo there are several choices, depending primarily on the engine and carburettor that you have.
        • jean
          • Oct 2015
          • 19
          not document
          • jean
            • Oct 2015
            • 19
            the engine is spitfire 1300
              Jean ! Are you sure its a Spitfire engine as your car is Marina based it is more likely to be a Marina 1300 "A" series engine. A photo of the engine will identify which engine you have.
                Ben, am I right in thinking that the 1300 Spitfire did not have a brake servo as standard?
                I agree that a Marina 1.3 seems more likely given the chassis number, the servo and single line brake master cylinder pictured in another thread, look Marina, but 3 different servos were fitted, principally different for 1.3 and 1.8 cars, so the engine size was of interest.
                As the Marina servo and brake master cylinder are now very difficult to find as NOS items, and there are no quick swaps (apart from the Peugeot mod) so I would suggest having the whole assembly refurbished J&L Spares Export. This gets around the identification problems as well.
                Pictures of the engine bay will help, as well as copies of any documentation, even the old V5 might give clues.
                It's a shame, a few days ago I was close to Montpelier, about 75km from Avignon, not planning to take that 8 hour drive again anytime soon.
                  All the small chassis Triumphs had the option of having a remote servo fitted (Girling Powerstop) by the Triumph agent although mostly on six cylinder cars.
                  This car has been converted to LHD so it is possible someone changed the engine to Triumph to move the manifolds and carbs out of the way. doubt it though!!
                    Yes I have seen that it has been converted to LHD but beneath the servo I can see what looks like an exhaust that exits in the standard Marina Roadster location above the chassis rail, and in the other I cannot see an exhaust pipe, though it may be under the car.
                    It all looks Marina, assuming that rarest of things a LHD Marina rack was fitted, but whatI can see of the front suspension it's Marina.
                    If it's a 1300 Marina donor, that narrows down the choice of servos, but it still needs replacing or refurbishing.
                    I hope the OP has checked the hydraulic braking system for leaks, and that the vacuum system is working, especially the check valve on the servo.
                    • jean
                      • Oct 2015
                      • 19
                      here are the photos
                      • jean
                        • Oct 2015
                        • 19
                          Yes that's a BMC A series engine nominal capacity1275cc most likely from the Maria.
                            Yes. Definitely not a Spifire engine. The servo is probably Marina so the chances are it's a 37H7844.
                            I recommend having the servo and master cylinder refurbished by J&L Spares Export Ltd. no other cars use the same servo.
                            • jean
                              • Oct 2015
                              • 19
