2 terminal oil press switch
    Any ideas where I can get a 2 terminal oil pressure switch for a Marina TC 1800 with anti run on?
    Re: 2 terminal oil press switch
    A lot of the Marinas were retro fitted with MGB or Metro Anti Run On valves. As far as I recall they all used single terminal switches.
    But, if memory serves right, some Triumphs used two and three terminal switches.
      Late GT6 use a 2 terminal switch which feeds the Anti run on valve. Try Rimmers.
        Thanks for the help I hope it is a GPS113 . Dave
