Thought I would do a nice easy job today and fill up with coolant, wrong!!!!!!!!!
Step 1; Remove bleed screw from water pump and fill with coolant until it comes out of hole. Replace bleed screw and snap off head with barely a touch.
Check
Step 2; Locate and modify new screw.
Check
Step 3; Snap off head of large inlet manifold bleed screw, again with barely a touch.
Check
Step 4: Try to remove broken piece with stud removal tool and crack inlet manifold.
Check
Step 5; Return to wife on couch with tail between legs and answer the "What took you so long" question.
Check
Step 6; Watch Scotland get beaten.
Check.
Step 7; Spend the rest of the evening on laptop trying to locate all the broken parts and lamenting how much it's all going to cost.
Ongoing.
Does brass go brittle with age???????
Check
Check
Check
Check
Check
Check.
Ongoing.
