Bike battery
This topic is closed.
    Bike battery
    Well here is the battery installed and turns the engine nicely.
    Loads of space on top of the bulkhead.
    And everything clears the bonnet.
    Now I just need to get some petrol.
    • 2797
    Re: Bike battery
    Super neat job - I guess the wires are farther away from the metal than they appear to be ?
      Re: Bike battery
      Yep trick of the camera. The stainless steel plate underneath is where the old battery box was. It really intruded into the passenger footwell. Plus I have moved the windscreen wiper motor to where the glovebox use to be. Never used the box anyway.
        • 2797
        Re: Bike battery
        Interesting. I was thinking about letting the battery box into there but wondered about passenger foot space, I think just make a new box on the bulkhead where the old one was.
        The wiper motor on Q67 was on t'other side for some reason, I'll have a look when I get to that stage. The build manual says drivers side, so dunno why it was there.
          Re: Bike battery
          If you put it on the passenger side behind the dash it doesn't have to bend so much.
          I found on my last roadster that because of the acute angle it made a lot of noise.
          Question though on my mk 2 manual it's says to put it on the passenger side?
            Re: Bike battery
            God you've got some wire brushing to do
              Re: Bike battery
              Possibly to do with the park switch...did the Triumph motor park the opposite way..?
              Mine also said passenger side which means the blades parked upright rather than flush. That said you can, IIRC, turn the park switch so that even with the motor on the passenger side you can park the blades along the bottom of the screen...wish I'd known that at the time before I made the cut outs in the bonnet to clear..!
              Worth noting that SVC can supply alternate wheelboxes and drive gears to improve sweep as the stock Marina setup is pretty poor in this respect. I've also wondered about adapting some of the after-market Mini arms fitted with a much stronger spring to improve blade/screen contact at speed.
                Re: Bike battery
                Good advise will look into it myself
                  Re: Bike battery
                  Well, the beast lives. The first time it's started under its own steam in 6 years.
                  Now the 100 and 1 things left to do.
                    • 2797
                    Re: Bike battery
                    Well done
