Hi Guys, latest problem is the throttle pedal on my Alfa powered Roadster. It is a push rod to a pivot under the carbs which then pulls down the throttle linkage.
As can be seen from above there is a nice long lever on the proper linkage which I assume gives a large amount of movement at the carbs for a small amount on the pedal. My problem is that the PO has made up a pedal design that has a tiny lever on it. This means that to get full movement at the carb the pedal has to sit ridiculously high (approx 75mm above brake pedal) to give the travel required for 0 to full throttle..
I have an idea to try and convert to some sort of pull cable design but would be most interested to find out what other Alfa cars are using.
Thanks again
Derek
Thanks again
Derek
	 . Any ideas on a suitable pedal?
