cooling V8
  • Michael Turpin
    • 172
    cooling V8
    General question -
    Does making the water pump go faster (compared with its manufactured speed in relation to the engine) have any benefits?
    Real Steel offer a new pump for the 3.5 V8 which has a smaller billet machined pulley making it run faster and saying its good for Hot Rods and Kit cars. But not for high revving engines.
    Does moving the water round faster just give it less time in the radiator to cool down? or am I missing something?
  • dbazdavies
    • 409
    Re: cooling V8
    have you tried the cooling adatives which seem to work ??
      • 709
      Re: cooling V8
      I would imagine it would move the heat away from the block quicker...but only assuming the pipework can handle the increased flow and the radiator is sized accordingly for the flow.
      Engine-driven pumps are optimised/compromised around a certain rev-range...idling they pump less than ideally required but higher up the rev-range may pump more than the rest of the system can handle...hence the warning.
      I'd suggest an upgraded radiator and if that doesn't help look at an electric pump & controller.
        • 1639
        Re: cooling V8
        I have read that the additives give little benefit as most antifreeze already has these properties? In my Marlin there is so much torque from the 3.9i V8 that you tend to use the higher gears when tootling along so engine revs are lower than they would be in a Land Rover. Hence the suggestion for using a smaller pulley / higher pump speed which may help for lighter / kit cars. However if the flow rate is too high no only does the rad not have time to cool the coolant but the other theory is that the coolant doesn't have time to absorb the heat from the engine.
        I believe that the fundamental problem is that the rad surface area in a Marlin is only about 40% of the area of the Land Rover Radiator, so there is insufficient cooling for the size of the engine.
        To overcome this I have added an extra rad under the front apron, plumbed in line with the main coolant circuit so it is controlled by the main engine thermostat. The result is no more cooling problems. I plan to do an article about this improvement for Pitstop in the near future. Peter.
          Re: cooling V8
          The head (press) will increase with speed - its a square law formulas will be on internet. As the system resistance will stay the same the flow rate will therefore increase as there is more pressure to overcome that resistance.
          It wont help. as the heat load from the engine is same and the ability for the radiator to cool is the same - all you will do is move coolant around faster at higher press putting strain on the pressure components (Hoses) and putting water pump seals and bearing under excess conditions.
          Don't do it
            Re: cooling V8
            I believe in the earliest days cooling relied on natural convection only. The pump was added to increase the rate of heat exchange, allow simplification of the design and reduce the volume of water. I have observed the rate of flow into a radiator and it is fairly slow. The thermostat restricts the flow when the cooling effect is too much. So don’t think increasing the speed will do much other than take a little more energy from the engine than is strictly necessary.
            Do you have a cooling problem? If so is it at rest or at speed? I have observed that most cooling problems in this country are due to incorrect mixture generating too much heat in the engine. Although, it is true that the shape of the Marlin engine compartment restricts the size of the rad and does not encourage good airflow around the engine.
            • ggrum
              • 782
              Re: cooling V8
              Pete, look forward to your article on the additional rad fitted to your V8 for Pitstop. No pressure (sorry about the pun!) but the deadline for the next issue is 25th March if you can manage it.
              • Michael Turpin
                • 172
                Re: cooling V8
                Thanks for all the comments and advise. The reason I asked was that during an engine out and replacement of the gearbox, when re assembled and filling the cooling system most of the coolant came back out of the small hole under the pump body, so in the search for a replacement I came across this one, however I did purchase a new unit from Rimmer Bros. which will be fitted in the next few days. I also look forward to the article on additional radiator but unfortunately that space is currently occupied by an oil cooler.
                Overall I don't have a cooling issue but I suspect its borderline and additional cooling will not go amiss. I did think another small rad under the wing may help. something like an inter-cooler
                  • 1639
                  Re: cooling V8
                  Ah yes! Forgot to mention I also have an oil cooler under there too!
                  I had considered rads under the wings but plumbing for the coolant gets rather tortuous.
                  Peter.
                  • lynnx22
                    • 67
                    Re: cooling V8
                    I understand modern multicore rads are considerably more efficient than old school ones. Made a big difference on a Mustang I once had.
                    Maybe coupled with a higher flow rate that would assist ?
                    Serves you right for stuffing such a huge engine in such a weeny car!
                    Tim
                      • 1639
                      Re: cooling V8
                      Tim
                      Not my fault guv'nor. It was what I found under the bonnet when I bought it! Peter.
                      • dbazdavies
                        • 409
                        Re: cooling V8
                        if did not have an Alfa in mine would fit a V8 just to hear the exhaust note !!!
                        • Michael Turpin
                          • 172
                          Re: cooling V8
                          Here,Here, V8s are for pleasure the fact that they need an awful lot of attention to run smoothly, not to mention the fuel, but then, if these requirements aren't for you don't put one in.
                          PS It was me who put it in so I can't complain, just enjoy it.
                          V8 Lover
                          The moving pistons,
                          such massive horsepower,
                          his cc's are tipping the scales,
                          those valves & rods are clicking,
                          revving rpm's to supersonic speeds,
                          spewing emissions to the
                          shifting gears of love.
                          Jonny Angel
                          • dbazdavies
                            • 409
                            Re: cooling V8
                            I had a TVR Chimera - 285 bhp - and if you did not go over 3000 revs (80mph top gear) it did mid 30's mpg most of the time - so in a Marlin should be the same if not more..
                            I happened to be lucky to have worked on the first SDI 3500 - and once set up properly they ran perfectly and then the fuel injection made it a lot easier !!! My Rover SDI Vitesse always did + 30 plus on runs - had a computer that told me sooo !!!
                              • 709
                              Re: cooling V8
                              Bit better than Dad's carb'd SD1 auto's...20mpg if you were lucky...mind you the kick-down was addictive..!
