Finally managed to finish my adjustable tie rods at the weekend...just need to finally fit and setup once my new caster gauge arrives.
For such a simple project this has been festering for ages for want of the ability to cut an external thread without the die wandering all over the place. I know others have achieved a similar setup through alternate means but my key objectives were to use readily available components, avoid scrapping anything Marina-specific, make the conversion readily reversible and avoid the need to weld anything.
A machine shop could have done it but none of the locals appeared very interested...so with vague thoughts about buying a lathe I went for the option of using a tailstock dieholder in my pillar drill to get the thread started...after that it was a breeze. There's nothing like the smell of warm cutting oil in the morning..!
To save cutting up the Marina tie bars I acquired a pair of scrap Minor ones for a fiver...the only bit you need is the end that goes in the fork on the lower arm (identical to Marina) and the diameter is 1/2", again the same as the Marina.
McGill Motorsports supplied a pair of 200mm turnbuckles, LH rod ends and spacers and www.thelatheman.com knocked me out a couple of top-hat bushes for a tenner (this is so I don't have to use a massive 3/4" bolt through the tie-rod chassis mount). The brackets were cut from some ERW box-section and whilst they are a little bigger than I wanted it was the only section I could find (easily & cheaply) which allowed me to avoid incorporating any of the weld-strip in the bracket itself.
Pics below.
Pics below.
