Would anyone have either a bulkhead or the dimensions of one for the triumph based Marlin please ??
Triumph Roadster Bulkhead
Tags: None
Re: Triumph Roadster Bulkhead
thanks guys - the reason I ask is that when fitting an Alfa engine in a Marlin roadster - especially when using a Marina bilkhead - is that the engine is too far forward and there is a clearence problem with the carbs being to near the engine side panel.. When I built my original one it was supplied with a Triumph bulkhead as they had never been asked for a kit to fit an alfa engine.. As you can see mine had room for air cleaners - I think that it is fitted about 4/5 inches further back and it also puts the gear lever in a better positionAttached Files
