I have wired in the ECU and double if not triple checked the circuits, but cannot start the engine. 4 wires from the ECU (15,18,30 & 53) I have left unconnected. I believe the problem is the wiring of the ignition module - Can any one help ? tel 01932 784045 evenings.
Carbio Ignition Wiring 2lt DOHC 8V
Tags: None
Re: Carbio Ignition Wiring 2lt DOHC 8V
Hello stuart
Don`t worry about the pins you mentioned.
I wired one of these in my cabrio and this is what I think.
Wires 15,18,53 are for the autobox actuator.
Wire 30 is for the autobox gearlever starter inhibit relay which was probably not fitted in the sierra manual doner.
I suspect your fuel pump is not running. Check that the pump runs for about 2 seconds, (for priming) when ignition is switched on. If not recheck the wiring for the fuel pump. ECU pin 22 (active low) is the driver for this, but realise that it cannot drive a pump directly (must use a relay)
ECU pin 36 is the ignition module driver, blue/red wire on the module. This will only switch when the ECU receives a timing pulse from the crank angle sensor, so to test this you will have to crank the engine and monitor this wire. Or
if ignition system is suspect simply connect a lamp across the coil primary terminals and crank the engine.
Hope this helps, if not I may be able to answer specific questions.
All the best
Peter
Message originally posted by: Keith Howell
What was your donor car? I have the complete set of electrical diagrams from Ford for the Sierra. You are welcome to come and copy the bits you need - I am based just north of High Wycombe. Call me on 01494 864351
