Mk2 front upper arms
  • Jonathanjeades
    • 225
    Really appreciate if someone can remind me what the front upper suspension arms are from on the marina based roadster.
    I've got quite a bit of play in the near side wheel but doesn't seem to be the wheel bearing. That being said I'm going to overhaul the front suspension with new upper and lower joints, new wheel bearings and am considering overhauling the upper arm to suspension mounts.
    Thanks in advance
    • 709
    Re: Mk2 front upper arms
    Classic Mini - dry version.
    Minispares et al do repair kits with new pins & needle rollers.
    • dbazdavies
      • 409
      Mini Spares own to original drawing specifications with heat treatment correctly applied where appropiate.Lack of proper maintenance (grease) will make the pivot shaft and/or bearings wear that much faster. In severe cases the shaft may rust to the bearin
        Certainly Classic Mini, actually wet or dry will work.
        here or there as published in Pitstop
        If you are talking about fore and aft movement.
        The repair kits I have seen all have had what I thought was excessive clearance issues. Ended up machining some that I was happy with,
