Re: SU Carb Refurbishment
Hi I have fitted a 2.0 zetec to my roadster if I can be any help please ask. It is running a standard rear axle and frount brakes but have put green stuff pads on the frount. The engine is running on bike carbs which I bought from Danst engineering and a nodiz ecu it's not that complicated to do, probably the hardest part is welding in new engine mounts in.
I will put some pictures up if you are intrested
Regards Angus
Regards Angus
