Rear handbrake auto adjust levers
  • davy66
    • May 2016
    • 30
    Hi I have a marina based mk1 marlin and I'm looking for a set of rear handbrake auto adjust levers and the clips that holds them in place, new or second hand I'm not fussy. I have attached a picture of Blue Marlin's who was kind enough to let me take a couple of pictures yesterday
    • 1644
    Re: Rear handbrake auto adjust levers
    My '67 MK2 Ford Cortina used exactly the same type of auto adjust. Not sure if it's exactly the same size but worth a check for possible source of old parts!
      One side on mine was snapped off, must have been difficult to do that to spring steel! No ill effect I just have to manually adjust the ratchet. Making a hole in the back plate would make it easier, but don't forget to grommet the hole!
      • davy66
        • May 2016
        • 30
        Thanks for both ideas, more digging to do and maybe a bit of drillingto do.
        • davy66
          • May 2016
          • 30
          Quick update, if anyone hits the same problem please see below, perfect fit
