Slave cylinder removal tool
    Hi
    Has anyone got a slave cylinder removal tool I can borrow.
    I seem to remember someone in the club had one.
    Re: Slave cylinder removal tool
    Assuming the engine is in the car, an easy method is to use a ratchet strap, hooked over the clutch lever and secured at the other end to the leaf spring. The only issue is that whilst you can pull the lever incrementally, releasing it is quite immediate.
