Brake Master cylinder (servo) for Ford Pinto 2.0 engined Berlinetta
  • paulratcliffe
    • May 2016
    • 7
    I am looking for a replacement Brake Master Cylinder (servo) for my Marlin Berlinetta (Q286 MNO) which was built using a MK3 Cortina donor vehicle.
    the number on the Master Cylinder casting is 596 4677683 (could be ...4677883). Can anyone point me in the right direction to locate the Master cylinder?
    Thanks
    • 930
    Re: Brake Master cylinder (servo) for Ford Pinto 2.0 engined Berlinetta
    I'd just search eBay
      you may find it easier to source a mk4 m/cylinder which has split circuit brakes, there was a thread on here about it somewhere.
      • philcoyle
        • 379
        Best to measure the inside diameter of the cylinder, then checkout www.brakeparts.co.uk for the cylinder you want. There are as one would expect several configurations, and as they say a picture paints a thousand words.
