Figured I'd start a new thread on this...
Despite passing the MOT yesterday, on the drive home from Perth, the rear drums began to make a groaning noise. I'd touch the brake pedal & it'd stop. Only to start again shortly afterwards.
Today I jacked it up, removed the wheels and the drums. The offside brake piston had leaked fluid all over the shoes & they were clearly not binding against the drum. By contrast the other nearside drum outer paintwork (red hammerite) was discoloured to a brown around the outer edge; it must have got pretty hot for that to happen. It otherwise seemed ok no leaks.
So I began to strip the offside brake components and now have the shoes removed and the pipes removed from the back & the handbrake disconnected too. I am stuck on removing the actual piston... I removed a rear rubber boot which was around it and there seems to be a flat metal rim on the area where the pipes screw in..? Can some kind Soul illuminate me on how to remove the piston from this stage?
This looks like a replacement part.. but I think I need to measure the one I have to be sure...
I think I will replace both rear pistons and shoes in one go..
One step forward, two steps back...
