Marina prop shaft and UJs
  • FranklinLeicester
    • 380
    My LWB 1275cc Marina engined Roadster needs a new rear UJ. On taking off the prop shaft I was surprised to see that the splined telescopic part was at the back by the diff. I was expecting it to be at gearbox end, don't know why - does it matter? My second observation was the lack of a grease nipple on the telescopic part. I know some do and some don't - year of manufacture maybe. I gave the sliding part a few gentle wacks so I could take it off to give the spline a good greasing. It was reluctant to come off so I gave up.
    Should this part come off easily?
    Franklin.
    Franklin, Leicester
  • FranklinLeicester
    • 380
    Re: Marina prop shaft and UJs
    Me again, I should have mentioned that I intend to do a DIY refurb job on the knackered UJ and also the "good" end too while I'm at it.
    I think they come in sets of 2.
    Franklin, Leicester
      I recall my A series based MK2 car having the splines the axle end and they should slide fairly easily for obvious reasons.
      • angusgrooby
        • 124
        Hi Franklin,I realise you would like to refurb yourself but I think these people are just down the road from you http://www.mjcengineering.co.uk/ they may be able to help.
          If I recall (and I am talking about mid 1970's) my 1300 Marina UJ went and it had to be machined out as it is crimped in not circlips - the guy who did it fitted it with circlip grooves. Also no grease nipple as they were sealed brgs. This last fact is more vague.
          • FranklinLeicester
            • 380
            Thanks for your comments. Yes Angus, they are 15 minutes drive from me. I'll give them a call.
            Franklin, Leicester
              Put the splined end at the gearbox. It gets less shaken about and lasts a lot longer but def. grease nipples on the joints and spline.
                Beware that some grease nipples get swiped off, particularly when the suspension is on full travel, not at maximum load, but when the prop is at the extreme angle as the rear axle/suspension is unloaded.
                • FranklinLeicester
                  • 380
                  Thanks for these further comments and advice. I have contacted MJC Eng'g as Angus suggests and will take it tomorrow morning and ask about grease nipples etc.
                  Franklin, Leicester
                  • FranklinLeicester
                    • 380
                    Left the shaft with them to do a full refurb, balance, the lot. £118 + VAT.
                    Franklin, Leicester
