Cabrio Coilover Data
    • 1648
    I have started this new post with a sketch and details that I have gleaned so far.
    It seems that the shorter (stiffer) springs have been used on my Hunter, maybe due to the weight of the V8 engine?
    Please send me a PM with any info that you have about your own cars and I will add it to the spreadsheet. Peter.
    CABRIO FRONT COILOVER DATA
    DIMENSIONS IN INCHES (UOS)
    SOURCE greyV8pete Happy Dave Mike W Dogoncrazy
    MAKE GAZ GAZ AVO GAZ
    PART No GP3116 B12E06 ? APF130/090 GP6 2338
    DIMENSIONS
    A (Fitted) 11.375 11.375 ?
    A (Fully Open) ? ? 13.00 ?
    A (Fully Closed) ? ? 10.50 ?
    B 4.450 4.375 ? ?
    C (Fitted) 5.250 5.250 ? ?
    L 8.250 8.250 ? ?
    t (Threads Visible) 25 22 ? ?
    N (Turns0 7 10 ? ?
    MODEL LWB SWB ? ?
    ENGINE Rover Ford Rover ?
    SIZE V8 2.0L Twin Cam V8 ?
    ENG WEIGHT (Kg) 230 ? ? ?
    SPRINGS
    MAKE GAZ GAZ AVO
    PART No ? ? E9250
    Length (Free) ? ? 9.00
    RATE (lb) ? ? 250
    WIRE DIA 9 mm 9 mm ?
    • 1648
    Re: Cabrio Coilover Data
    My P/No edited and my further dims added. Peter.
    PART No GP31168 B12E06 ? APF130/090 GP6 2338
    DIMENSIONS
    A (Fully Open) 12.75 ? 13.00 ?
    A (Fully Closed) 10.50 ? 10.50 ?
    B 4.450 4.375 ? ?
    L 8.250 8.250 ? ?
    N (Free Turns) 7 10 ? ?
    MODEL LWB (Hunter) SWB (Hunter) ? ?
    SPRINGS
    MAKE GAZ GAZ AVO
    PART No ? ? E9250
    Length (Free) 8.50 ? 9.00
    RATE (lb) ? ? 250
    WIRE DIA 0.375 9 mm ?
    Link below for spring rate calculator:
    Last edited by greyV8pete; 27-08-16, 07:32 AM. Reason: Spring rate calculator link added.
      • 1648
      If anyone can have a look under their Cabrio / Hunter with a tape measure over this weekend and let me have their info I would appreciate it. I want to phone GAZ with an order on Tuesday and any more data available will be really useful. Many thanks. Peter.
      P.S. The deleted post above was a failed attempt to embed the pic to make it viewable without people having to log in. P.
        • 1648
        Latest data update below:
        SOURCE greyV8pete OLD greyV8pete NEW
        Happy Dave Dogoncrazy Mike W drover pete ggrum
        MAKE GAZ GAZ GAZ GAZ AVO AVO AVO
        STAMPED PART No GP31168 B12E06 GP6 2338 APF130/090 K2 974 ? ?
        DAMPERTECH REF 130/090 B12 - 2
        DIMENSIONS
        A (Fitted) 11.375 11.500 11.375 11.250 11.125 11.500 11.600
        A (Fully Open) 12.75 13.00 13.00 13.38
        A (Fully Closed)* 10.50 10.00 10.50
        B 4.450 4.250 4.375 2.250 2.875 2.625 3.150
        C (Fitted)*** 5.250 5.750 5.250 6.25 6.50 6.000
        L 8.250 7.750 8.250 8.250 8.125 8.250
        t (Threads Visible)** 25 23 22 none! NS 3 / OS 8
        N (Free Coils) 8 8 10 9 7 9 8
        MODEL LWB (Hunter) LWB (Hunter) SWB (Hunter) LWB (Cabrio) SWB
        ENGINE Rover Rover Ford BMW M20 Rover Ford
        SIZE V8 V8 2.0L Twin Cam V8 2.0L DOHC
        ENG WEIGHT (Kg) 230 230 258
        SPRINGS
        MAKE GAZ GAZ GAZ AVO AVO
        PART No 2.25 x 9 x 225 E9250
        Length (Free) 8.50 9.00 9.00
        RATE (lb) 200 / 210 (Test) 225 250 225 (Calcd)
        WIRE DIA 9.5 mm 9.5 mm 9 mm 7/16" 9 mm 0.375
        INTERNAL DIA 2.25 2.25
        END BUSHES
        BOLT HOLE 0.50 0.50
        BUSH WIDTH 1.25 1.25
        Note * 1 - /090 in part number is distance between body and metal top flange. The 1" bump rubber makes the actual fully closed dimensio 10" as shown.
        Note ** 2 - Adjustment threads visible shown for reference only - Different makes and part numbers will not read across!
        Note *** 3 - The new coilovers have the bottom of the body much closer to the lower bolt bush so differences will appear for some dimensions.
        Note! - Old type Marlin (solid) wishbones need smooth tapering radius grinding to ensure body will not foul at extreme rebound! Later tubular type do not.
        ADJUSTING COILOVERS
        A few notes about adjusting coilovers while still fitted to the car.
        Before attempting to adjust the spring seats on coilovers that have been in service for some time be sure to note the following:
        • Wire brush all exposed threads on the body to remove any rust or corrosion.
        • Spray the threads with Plus Gas or penetration oil. Leave to stand overnight!
        • Oil the top C- shaped spring seat where it fits against the top flange of the piston rod.
        • Oil the threads above and below the adjuster ring
        • Loosen the locking grub screw in the edge of the adjuster ring.
        • Jack under the centre of the front cross member so both front wheels are off the ground.
        • Use the correct size C-spanner to rotate the bottom spring adjuster ring.
        • Don’t forget to tighten the locking grub screw after final adjustment.
        Hope all this helps.
        Peter.
