Roadster chassis
  • thackery
    • Jun 2016
    • 55
    Roadster chassis
    Hi All a question what's the chances of a roadster chassis still being sound after 26 years in a canvas garage this is on a fully built car !
    Re: Roadster chassis
    If it has not had water standing on it, I'd say pretty good: the converse applies.
    • thackery
      • Jun 2016
      • 55
      As far as I can tell the canvas garage kept it dry it just looks like condensation rust on most metal parts and even thin items have stayed solid
        Weren't the Roadster chassis all carefully welded up so as to not have the innards open to the elements? Should help a lot in reducing internal corrosion.
          If its a Marina or hybrid chassis the most vulnerable area is the single skin panel below the door where the wing bolts up.
          • d068795n
            • Feb 2016
            • 18
            Had my chassis for 34 years, still as good as new. Been kept in unheated garages all this time
              Mine too, after 6-9 yrs outside under a tarp.
              • thackery
                • Jun 2016
                • 55
                Well that sounds promising I will soon find out thanks .
                  Echoing Ben...my low mileage hangar queen was decidedly crusty below the doors when the wings last came off.
                    • 929
                    Mine too. I think that the wing rubs on the chassis where it touches wearing through the paint. A little oil is probably the best protection.
                    • philcoyle
                      • 379
                      The best way to cure that problem is to fit wing beading between wing and body, also cuts out a lot of squeaks made by body flexing.
                      Don't go for the plastic stuff use the old type pvc and fabric, you could even fit it without removing the wings and running boards by cutting slots in it and by slacking off the mounting bolts.
                      Just an idea, I did mine about 14 years ago never looked back'
                      If you choose to remove the wings etc. fit the beading in place with doublesided sailmakers adhesive tape, its stickier than a sticky thing.
