Door length
  • dbazdavies
    • 409
    Door length
    Does anyone know the door lengths of the SWB and LWB roadster and also wheel base lengths please ??
    • 685
    Re: Door length
    Wheel base SWB/ LWB - 2337mm/ 2489mm
    Edit: SWB door length 695mm measuring from top corner at door shut horizontally. I understand the LWB is 6" longer.
      Re: Door length
      I thought 4" danny will know!!
      • dbazdavies
        • 409
        Re: Door length
        Thanks guys seems my car is a SWB !!!!
          Re: Door length
          The difference is in the door length LWB 2489mm minus SWB 2337mm equals 152mm which is 6 inches in old money.
          • dbazdavies
            • 409
            Re: Door length
            Does anyone know if all the SWB roadsters were made with wood doors covered in alloy as have seen others made just from alloy with an internal door lock !!
              • 1235
              Re: Door length
              Early models were wood with an alloy skin, then developed to an all alloy fabricated door, and yes the difference in door length between swb and lwb is 6 inches. There were also one piece front wings on MK1 cars then seperate inner and outer in glass fibre then alloy inners . and there is more,----------
              • dbazdavies
                • 409
                Re: Door length
                cheers guys a wealth of information for sure !!!
