The following are Ford Autodata Track Settings & Tolerances:
Wheelbase mm: 2609
Track - front/rear mm: 1453/1468
Tightening torques
Tightening torque - steel wheels : 100 Nm
Tightening torque - alloy wheels : 100 Nm
Trackrod locknut/clamp : 57-68 Nm
Checking range - Front wheels
Load positioning :Unladen
Toe-in (N = negative, toe-out) mm: 0,50N - 4,50P
Toe-in deg: 0°5´N - 0°45´P
Toe-in deg-1/100: 0,08N - 0,75P
Camber deg: 1°20´N - 0°40´P
Camber deg-1/100: 1,33N - 0,67P
Castor deg: 0°50´ - 3°20´
Castor deg-1/100: 0,83 - 3,33
Setting data - All wheels
Toe-in (N = negative, toe-out) mm: 2±1
Toe-in deg: 0°20´±10´
Toe-in deg-1/100: 0,33±0,17
Camber deg: 0°20´N±1°
Camber deg-1/100: 0,33N±1
Tolerance left/right deg: 1°15´
Tolerance left/right deg-1/100: 1,25
Camber adjustment :Not adjustable
Castor deg: 2°5´±1°15´
Castor deg-1/100: 2,08±1,25
Castor adjustment :Not adjustable
Rear toe-in mm: 0,80±3,25
Rear toe-in deg: 0°8´±34´
Rear toe-in deg-1/100: 0,13±0,57
Rear toe-in adjustment :Not adjustable
31 Rear camber deg:
32 Rear camber deg-1/100:
Rear camber adjustment :Not adjustable
Fig.78005
X1 = 350-359 mm 1°52'N±1°10'
X1 = 360-369 mm 1°29'N±1°10'
X1 = 370-379 mm 1°7'N±1°10'
X1 = 380-389 mm 0°44'N±1°10'
X1 = 390-399 mm 0°22'N±1°10'
X1 = 400-409 mm 0°±1°10'
X1 = 410-419 mm 0°23'±1°10'
X1 = 420-429 mm 0°46'±1°10'
X1 = 350-359 mm 1,87N±1,17
Important Note Page 1 of 2
http://www.autodata-online.net/Onlin...quisite.aspx?c... 26/07/2013
Fig.78005
X1 = 360-369 mm 1,48N±1,17
X1 = 370-379 mm 1,12N±1,17
X1 = 380-389 mm 0,73N±1,17
X1 = 390-399 mm 0,37N±1,17
X1 = 400-409 mm 0±1,17
X1 = 410-419 mm 0,38±1,17
X1 = 420-429 mm 0,77±1,17
Important Note Page 2 of 2
Wheelbase mm: 2609
Tightening torques
31 Rear camber deg:
Fig.78005
Fig.78005
